Hello I am looking to replicate the application shown in the file named “MITCheetah.pdf” here
https://drive.google.com/drive/folders/1h12dyPrnRxhy5vV2ko2OF1hHnejn13jg?usp=sharing
I have tried using this brushed DC motor Pololu - 4.4:1 Metal Gearmotor 25Dx63L mm HP 6V with 48 CPR Encoder but I am having trouble controlling it. It seems like this motor might be better suited for velocity control like for a fan application. I am having difficulty using the Hall effect quadrature encoder to control position.
I need to control the angular position of the rotor reasonably precisely in order to control the position of the foot (see the document). The movement does not need to be as rapid as the movement I am observing from the DC brushed motor.
I was looking at a stepper motor. Pololu - Stepper Motor: Bipolar, 200 Steps/Rev, 35×36mm, 2.7V, 1 A/Phase
I have gone pretty far down the 4801 path at this point, but I thinking I am beginning to run up on some fundamental control limits.
Can you make a recommendation as to which motor might be the preferred motor for my application? Also could you make a recommendation on any additional hardware (ie shields) that I could use to control the motor with Arduino/Raspberry PI.
