I’m currently working on a RC car project. Im using the MC33926 Shield on my Arduino - only M1 being connected. The motor itself is basically just an cordless drill from BOSCH (like the BOSCH PSR 14,4-2). Im using the battery provided with the drill. I just connected the M1A and M1B connections to the terminals of the drill and the power from the battery goes to VIN and GND of the shield - It runs perfectly, but when I quickly change the speed (like from 270 to 0, 400 to 0) the motor detects a fault. When i slowly lower the speed, everything works fine. Its just as soon as the speed is being changed quickly that I get those problems. The behavior occurs when the speed is bigger than ~250. The current at a speed of 250 is about 2.4 amps, at 400 it is about 4.6 amps.
