Can anybody suggest a driver for the below motor to work with arduino?
https://robokits.co.in/e-bike/e-bike-motor/ebike-dc-geared-motor-24v-300rpm-350w
Can you tell us what you are using for a power supply and its voltage?
-Derrill
Power supply is a li-ion 24V, 72Ah battery.
You might consider using one of our G2 High-Power Motor Driver 24v21, but it might be a little underpowered since it is not clear what your motor’s stall current is. You might also consider one of the RoboClaw motor controllers if you think your motor has a large stall current or will be under heavy loads.
-Derrill
Can you tell me what value of capacitor is required to connect across the supply?
-Pabel
In general, it will depend on your system and what it needs. You could try a few hundred µF and add more if you experience problems.
-Derrill
