I’m interested in picking up one of these NEMA 8 stepper motors, but before I commit to buying one and waiting for it to ship I wanted to draft up a quick CAD model of the application I had in mind to see how it might fit.
I see that there is a little cable connector on the side, but there are no dimensions associated with it in the datasheet spec. Can someone please provide some measured values for the dimensiosn I’ve added in red?
I measured one of those stepper motors here and found H on your diagram to be about 7.5mm and W on your diagram to be about 11.6mm. The dimension H in your diagram doesn’t go to the back of the stepper motor; the dimension going to the back of the stepper motor would be about 8.7mm. Also, if you are making a model it might help to know the connector sticks out about 2.0mm off the side of the stepper motor, and the wires actually go off the back of the stepper motor as shown in the product picture.
