So I am making a robot for a class and I have two Xbee shields each connected to a different arduino. On one side is the controller and the other the robot. On the robot side I am trying to use the micro serial servo controller to manage servo control. I had to make a software serial port as the hardware one is already being used by the Xbee. The thing is after doing this everything is acting weird.
Before my controller and robot communicated just fine. Now the robot doesnt seem to get signals from the controller. But I can connect it via USB and use the serial monitor to send it commands.
The servo controller is acting even more strange. It was working I could send it an angle (Via USB to the arduino) and it would move the servo, then it would frequently for seemingly no reason go red light on me, I would reset the whole thing and try again. Now for some reason the servo controller has no lights (red, yellow or green) and it just spins the servo round and round endlessly.
What gives?
**** CONTROLLER CODE ****
//Controller Code; Arduino Duemilanove ATmega328
//---PINS---//
//number of digital pins on the Duemilanove used to set analog pin modes
const int DigitalPins = 14;
//LEDS
int RED_LED = 3;
int GREEN_LED = 4;
//Digital pins
const int RunSwitch = 5;//digital pin the run switch is on
const int DrivePush = 6;
const int ClawPush = 8;
//Analog pins
const int FrdPot = 0; //Analog pin that the Forward axis pot is on
const int TrnPot = 1;//Analog pin that the turning axis pot is on
const int RaisePot = 2; //Analog pin that the Raise/Lower axis pot is on
const int OpenPot = 3;//Analog pin that the Open/Close axis pot is on
const int TrimFrdPot = 4; //Analog pin that the Trim Forward axis pot is on
const int TrimTrnPot = 5;//Analog pin that the Trim turning axis pot is on
//---END PINS---//
//---Values---//
int State = 0;//state condition values; run switch high/low
int DELAY = 30; //delay between serial commands in milliseconds
const int DeadSpace = .10;
//Motors
const int POW = 140; //Max PWM power possible is actually 3/4*POW
//Acceptable values range from 0 to 340
//Motor computation variable
//int Frd = 0;
//int Trn = 0;
int TrimF = 0;
int TrimT = 0;
int drive = 0;
int turn = 0;
int LeftM = 0;
int RightM = 0;
//Left motor controls
int LM_IN1_Val = 0;
int LM_IN2_Val = 0;
//Right motor control
int RM_IN1_Val = 0;
int RM_IN2_Val = 0;
//Claw Values default angles at power on.
int Raise = 90;
int Open = 30;
int AngleInc = 3;
//State of claw stick push button
int ClawPushS = 0;
//State of drive stick push button
int DrivePushS = 0;
//Min and Max servo angles
const int MinRaise = 0;
const int MaxRaise = 130;
const int DefaultRaise = 100;
const int MinOpen = 0;
const int MaxOpen = 130;
const int DefaultOpen = 100;
//--END Values---//
void setup()//the main initialization function
//Pinmode initialization
pinMode(RunSwitch, INPUT);//the run switch pin
pinMode(RED_LED, OUTPUT);
pinMode(GREEN_LED, OUTPUT);
pinMode(FrdPot+DigitalPins, INPUT); //Forward axis potentiometer pin
pinMode(TrnPot+DigitalPins, INPUT);//Turning axis potentiometer pin
Serial.begin(38400); //starts the serial communication at 38400 baud rate
}//end Setup()
void control()
//Reading pushbuttons on each stick
ClawPushS = digitalRead(ClawPush); //launch command
DrivePushS = digitalRead(DrivePush);// resets claw to default position
if(DrivePushS == 1)
Raise = DefaultRaise;
Open = DefaultOpen;
int deadClawStick = 15;
//Reading Claw Control values and setting corresponding angles.
if(map(analogRead(RaisePot),0,1023,-100,100)>deadClawStick)
if(Raise > 180)
Raise = 180;
else
Raise = Raise + AngleInc;
if(map(analogRead(RaisePot),0,1023,-100,100)<-deadClawStick)
if(Raise <0)
Raise = 0;
else
Raise = Raise - AngleInc;
if(map(analogRead(OpenPot),0,1023,-100,100)>deadClawStick)
if(Open > 180)
Open = 180;
else
Open = Open + AngleInc;
if(map(analogRead(OpenPot),0,1023,-100,100)<-deadClawStick)
if(Open<0)
Open = 0;
else
Open = Open -AngleInc;
//Reading the drive control pot values and re mapping to a new scale
drive = map(analogRead(FrdPot),0,1023,-POW/2,POW/2)+TrimF;
turn = map(analogRead(TrnPot),0,1023,-POW/4,POW/4)+TrimT;
if (drive <=DeadSpace*POW/2 && drive >= -DeadSpace*POW/2)
drive = 0;
if (turn <=DeadSpace*POW/4 && turn >= -DeadSpace*POW/4)
turn = 0;
//TrimF = map(analogRead(TrimFrdPot),0,1023,-100,100);
//TrimT = map(analogRead(TrimTrnPot),0,1023,-100,100);
//Raise = map(analogRead(RaisePot),0,1023,-100,100);
//Open = map(analogRead(OpenPot),0,1023,-100,100);
/* Motor pin breakdown
Forward = IN1 HIGH, IN2 LOW
Backwards = IN2 HIGH, IN1 LOW */
//simple algorithim to achieve driving+turning together
//drive = map(Frd,-100,100,-POW/2,POW/2)+TrimF;
//turn = map(Trn,-100,100,-POW/4,POW/4)+TrimT;
LeftM = drive-turn;
RightM = drive+turn;
if(RightM>0)//right motor forward drive
//Right Forwards
RM_IN1_Val = RightM;
RM_IN2_Val = 0;
else if(RightM<0)//right motor reverse
//Right Reverse
RM_IN1_Val = 0;
RM_IN2_Val = abs(RightM);
if(LeftM>0)//left forward
//Left Forwards
LM_IN1_Val = LeftM;
LM_IN2_Val = 0;
else if(LeftM<0)//Left Reverse
//Right Reverse
LM_IN1_Val = 0;
LM_IN2_Val = abs(LeftM);
}//end control()
void com()
//USED LETTERS
// x - end command char
// S - State condition switch
// Q - LM_IN1 Value
// W - LM_IN2 Value
// E - RM_IN1 Value
// R - RM_IN2 Value
// O - Claw; open close set angle
// U - Claw; raise lower set angle
// L - Launch Solenoid state
//STATE CONDITION VALUE
Serial.print('S');//State condition switch value character
Serial.print(State);//State condition switch value
Serial.print('x');//end command character
delay(DELAY);
//LEFT MOTOR VALUES
Serial.print('Q');//LM_IN1 value character
Serial.print(LM_IN1_Val);
delay(DELAY);//delay to ensure the commands are recieved seperately
Serial.print('W');//LM_IN2 value character
Serial.print(LM_IN2_Val);
//RIGHT MOTOR VALUES
Serial.print('E');//RM_IN1 value character
Serial.print(RM_IN1_Val);
Serial.print('R');//RM_IN2 value character
Serial.print(RM_IN2_Val);
//CLAW POSITION VALUES
Serial.print('O');//Open/close claw value character
Serial.print(Open);
Serial.print('U');//Raise/Lower claw value character
Serial.print(Raise);
//Launch State
Serial.print('L');//Open/close claw value character
Serial.print(ClawPushS);
Serial.print('\n');
}//end Com()
void loop()
State = digitalRead(RunSwitch);//checking the run state first
//Serial.print(State);
//Serial.print('\n');
control();//running the control function
//LED status indicator
if(State == 1)
digitalWrite(GREEN_LED, HIGH);
digitalWrite(RED_LED,LOW);
com();//running serial communication function
if(State == 0)
digitalWrite(GREEN_LED, LOW);
digitalWrite(RED_LED,HIGH);
LM_IN1_Val = 0;
LM_IN2_Val = 0;
RM_IN1_Val = 0;
RM_IN2_Val = 0;
}//end Void loop()
**** ROBOT CODE****
//Reciever Code; Arduino Mega (ATmega1280)
A large portion of the code for the serial communication with the servo controller was borrowed from Hannes Hassler who himself
credited Tom Igoe, David Mellis and Heather Dewey-Hagborg and individuals that were active in the thread
'https://forum.pololu.com/t/arduino-pololu-micro-serial-8-servo-controller/613/1&highlight=arduino'
discussing mostly between Adam, Phil and Zagrophyte
Code sourced from
https://forum.pololu.com/t/arduino-and-micro-serial-servo-controller/993/1
#include <SoftwareSerial.h>
#include <math.h>//include the floating point math library
#include <Servo.h>//include the Servo library
//---PINS---//
//LEDS
const int RED_LED = 34;
const int GREEN_LED = 30;
//Servo numbers on pololu board
const int RaiseServo = 1;
const int OpenServo = 2;
//Serial com with driver
#define reset 13
#define rxPin 12
#define txPin 11
//spoofing a serial port
SoftwareSerial mySerial = SoftwareSerial(rxPin, txPin);
//MOTOR DRIVER PINS
//Forward = IN1 HIGH, IN2 LOW
//Backwards = IN2 HIGH, IN1 LOW
//Left Motor
const int LM_IN1 = 7;
const int LM_IN2 = 6;
//Right Motor
const int RM_IN1 = 5;
const int RM_IN2 = 4;
//---END PINS---//
//---Values---//
//State position
int State = 0;
int Debug = 0;
//Drive values
int LM_IN1_Val = 0;
int LM_IN2_Val = 0;
int RM_IN1_Val = 0;
int RM_IN2_Val = 0;
//Claw Values
int Raise_Ang = 0;
int Open_Ang = 0;
//Launch State
int Launch = 0;
//--- END Values---//
void setup()//main initialization function
//Servo controller serial communication initialization
// define pin modes for tx, rx, led pins:
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
pinMode(reset, OUTPUT);
//Reset the Pololu Servo controller
resetPololu();
//Begin mySerial at a baud rate of 9600
mySerial.begin(9600);
//pinmode initialization for status indicating LEDs
//Pinmode initialization for motor driver
//Left
pinMode(LM_IN1, OUTPUT);
pinMode(LM_IN2, OUTPUT);
//Right
pinMode(RM_IN1, OUTPUT);
pinMode(RM_IN2, OUTPUT);
//Pinmode
//Serial communication initialization
void servos()
send2Pololu(RaiseServo,Raise_Ang); //Open close servo
send2Pololu(OpenServo,Open_Ang); //Raise lower servo
void resetPololu()
digitalWrite(reset, LOW);
delay(100);
digitalWrite(reset,HIGH);
}//END resetPololu
void send2Pololu(int servo, int IntAngle)
int angle = map(IntAngle,0,180,500,5500);
unsigned char buff[6];
unsigned int temp;
unsigned char pos_hi,pos_low;
//Convert the angle data into two 7-bit bytes
temp=angle&0x1f80;
pos_hi=temp>>7;
pos_low=angle & 0x7f;
//Construct a Pololu Protocol command sentence
buff[0]=0x80; //start byte
buff[1]=0x01; //device id
buff[2]=0x04; //command number
buff[3]=servo; //servo number
buff[4]=pos_hi; //data1
buff[5]=pos_low; //data2
//Send the command to the servo controller
for(int i=0;i<6;i++){
mySerial.print(buff[i]);
}//End send2Pololu
void servoSetSpeed(int servo, int speed)
//servo is the servo number (typically 0-7)
//speed is servo speed
//(0= no speed limiting, 1=slowest, 127=fastest)
unsigned char buff[5];
unsigned char speedcmd;
speedcmd=speed&0x7f;//take only lower 7 bits of speed
buff[0]=0x80;//start byte
buff[1]=0x01;//device id
buff[2]=0x01;//command number
buff[3]=servo;//servo number
buff[4]=speed;//data1
for(int i=0;i<5;i++){
Serial.print(buff[i],BYTE);
void servoOff(unsigned char servo)
{ //turns off a servo
//(servo will go limp until next position command)
//Send a Pololu Protocol command
Serial.print(0x80,BYTE);//start byte
Serial.print(0x01,BYTE);//device id
Serial.print(0x00,BYTE);//command number
Serial.print(servo,BYTE);//servo number
Serial.print(0x0f,BYTE);//data1 (turn servo off, keep full range)
void com()//communication function used for serial communication between arduinos
int val = 0;//variable used to track char to number values
if(Serial.available()>0)//if Serial data is in the buffer
int ByteSize = Serial.available();//determining the size of incoming data
char data[ByteSize];//initializing the data[] variable
for(int i=0; i<ByteSize; i++)//populating the data array
data[i] = Serial.read();
//DONE READING INPUT DECODE AND SET VALUES
// D - Debug command
// Q - LM_IN1 Value
// W - LM_IN2 Value
// E - RM_IN1 Value
// R - RM_IN2 Value
if(data[0] == 'D')//Debug command outputs values via serial
int power; //tracking the power of ten that any given int has
for(int i=1; data[i]!='x' ;i++)//for all bytes not the end byte
power = ByteSize-2-i;//power of ten
val = val+(data[i]-48)*pow(10,power);//converting the bytes from char to int
Debug = val;
}//end if 'S'
if(data[0] == 'S')//State condition switch
State = val;
}//end if 'S'
if(data[0] == 'Q')//LM_IN1 value
LM_IN1_Val = val;
}//end if 'Q'
if(data[0] == 'W')//LM_IN2 value
LM_IN2_Val = val;
}//end if 'W'
if(data[0] == 'E')//RM_IN1 value
RM_IN1_Val = val;
}//end if 'E'
if(data[0] == 'R')//RM_IN2 value
RM_IN2_Val = val;
}//end if 'R'
if(data[0] == 'O')// Open/Close servo angle
Open_Ang = val;
}//end if 'O'
if(data[0] == 'U')// Raise/Lower servo angle
Raise_Ang = val;
}//end if 'U'
if(data[0] == 'L')// Launch State value
Launch = val;
}//end if 'L'
}//end if serial available
}//end com()
void launch()
digitalWrite(Sol,Launch*255);
void LED()
if(State == 1)// GREEN LED: Run state == GO
else //RED LED: Robot dead (Or possibly error): Run state == STOP
}//End LED()
void KILL()
//Killstate motor values
RM_IN1_Val = 0;
RM_IN2_Val = 0;
LM_IN1_Val = 0;
LM_IN2_Val = 0;
//Killstate servo angles
Raise_Ang = 100;
Open_Ang = 100;
//Killstate Launch status
Launch = 0;
}//END KILL()
void drive()
//Left
analogWrite(LM_IN1,LM_IN1_Val);
analogWrite(LM_IN2,LM_IN2_Val);
//Right
analogWrite(RM_IN1,RM_IN1_Val);
analogWrite(RM_IN2,RM_IN2_Val);
}//end drive()
void deBug()
Serial.print("State = ");
Serial.print('\n');
Serial.print("*** LEFT MOTOR ***");
Serial.print('\n');
Serial.print("LM_IN1 = ");
Serial.print('\n');
Serial.print("LM_IN2 = ");
Serial.print('\n');
Serial.print("*** RIGHT MOTOR ***");
Serial.print('\n');
Serial.print("RM_IN1 = ");
Serial.print('\n');
Serial.print("RM_IN2 = ");
Serial.print('\n');
Serial.print("*** SERVO ANGLES ***");
Serial.print('\n');
Serial.print("Raise/Lower angle = ");
Serial.print(Raise_Ang);
Serial.print('\n');
Serial.print("Open/Close angle = ");
Serial.print(Open_Ang);
Serial.print('\n');
Serial.print("*** LAUNCH STATE ***");
Serial.print('\n');
Serial.print("Launch = ");
Serial.print(Launch);
Serial.print('\n');
Serial.print('\n');
void loop() //Main loop
com();//listen for signals from controller
if(Debug == 1)
deBug();
if(State==1)//Runstate == RUN (runswitch high)
//Enable run functions
drive();
servos();
launch();
LED();
else//killswitch engaged
//Motors servos and launch solenoid set to stop values
KILL();
//Continually ping the motors servos and launch at the stop values
drive();
servos();
launch();
//indicate status
LED();
}// end kilswitch engaged
}//end main void() loop
