hi,
is there a maximum length for the cable between a Tic and the corresponding stepper?
rolf meesters
hi,
rolf meesters
We do not have a specification like that for the Tics since it would depend on what size wires you use and how much voltage drop across the wires is tolerable in your application. How far do you expect the Tic to be from your stepper motor in your setup?
- Patrick
Patrick via Pololu Forum schreef op 18-01-2021 23:23:
| PatrickM Pololu Employee
January 18 |
- Patrick
Visit Topic or reply to this email to respond.
To unsubscribe from these emails, click here.
hi Patrick,
in our (art-)installation it could be 10 meters.
rolf
We have not made a setup with the Tics where the motors were that far away from them ourselves, but you will probably be okay if you use thick wires. I would also suggest soldering your wires directly to the Tic’s outputs instead of using the included terminal blocks, and you might measure the voltage drop across your wires once it is set up to make sure it is not too bad.
- Patrick
