Hello guys.
Updated:
the Errors were fixed by running : sudo apt-get install libmono-system-windows-forms4.0-cil
now I can run turn on the Maestro Control Center on Ubuntu,
but another error occured:
" Failed to load module “canberra-gtk-module” "
"there was an error while starting up. Error connecting to the device to get serial number (9 of 21, 5578ac8001d0), Access denied. "
I am using Maestro Servo linux-150116.tar.gz] Controller Linux Software to run the Maestro Control Center on Ubuntu 20.0.
I followed the instructions from the Readme.txt, the steps looks like this:
since the ‘libmono-winforms2.0-cil’ is not available, I installed ‘libmono-winforms4.5-cil’,
~ sudo apt-get install libmono-accessibility4.0-cil** ,
then,
**~ sudo udevadm control --reload-rules,
then run the controller,
:~/Downloads/maestro-linux$ ./MaestroControlCenter
WARNING: The runtime version supported by this application is unavailable.
Using default runtime: v4.0.30319
Unhandled Exception:
System.IO.FileNotFoundException: Could not load file or assembly ‘System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’ or one of its dependencies.
File name: ‘System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’
[ERROR] FATAL UNHANDLED EXCEPTION: System.IO.FileNotFoundException: Could not load file or assembly ‘System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’ or one of its dependencies.
there is a Error, and the controller pannel didn’t show up.
the error/user LED on board is in Red
anyone has clue about this?
thank you in advance.
– Lisheng
