Maestro Controller Hardware Components
Hi Everyone,
l need help with component parts of the pololu maestro circuit board hardware. Questions can be found in the following link:
They’re are about 4 component that l am not aware what the hardware is called and their functionalities, l would like to know their functionalities.
Thanks
Hi.
I moved your post to the servo controllers and servos section of the forum.
We do not disclose the schematic or bill of materials for the Maestros. Is there a specific reason you are interested?
-Claire
Hi Claire,
Thank you for following up. l am interested in knowing the schematic for upgrading purposes the maestro presently only operates servo and not brushless motors, what l need it to operate,brushless motors. l want to create a Maestro that can conduct upto 120Volt and believe, l will need to upgrade the maestro components, hence the reason for knowing schematic details.
Best Regards,
Dustin
That sounds like a lot more than an upgrade! You would need all new hardware to control brushless motors and accept 120V power, so I do not think knowing the components used on our Maestros would be very helpful anyway. I recommend looking into brushless motor drivers and controllers.
-Claire
Hi David,
Please reach me. This is not relevant to the Wixel SDK on Linux Ubuntu topic. l need your assistance.
l see you are the software developer responsible of Pololu Maestro Controller Coding. GitHub - Elvis485/pololu-usb-sdk: Example code for making your own PC applications that control Pololu USB. l would like to work with you in upgrading the pololu maestro servo controller to operate 40 to 60 AC / DC Brushless Motors with around 120 Volt Input and Output to a MicroController.
The current Pololu Maestro Servo Controller can only support up to 24 volts.
l will buy each Upgraded Pololu Maestro Servo Controller for $140. l believe, l will be buy a minimum of 12 per year.
Please let me know how soon we can start.
Pololu Maestro Servo Controller User’s Guide
Thanks
Elvis Ogutu
987OnlineCentral
[management@987onlinecentral.com]
1402 Corinth St #2100, Dallas, TX 75215
Hi, Elvis.
I moved your post to this thread where you previously asked about the same kind of alterations to a Maestro since, as you mentioned, your post is not related to the Wixel SDK.
As I mentioned before, your request is not an upgrade. It would require a totally new design, which is currently not practical for us to work on.
-Claire
