I’m am trying to control two linear actuators with two Jrk 21v3 boards. I have a problem with one, that doesn’t happen on the other and I’ve run out of ideas for what is wrong.
I am connecting both over USB, if I connect them using my Windows machine, the Jrk Configuration Utility has no issues finding both devices. However, the final project is done on a Linux machine. Both of them are enumerated as /dev/ttyACM0 through /dev/ttyACM3 correctly, but my code only is able to communicate with one of them.
I also tried the JrkCmd utility to see if it was my code. For one, ./JrkCmd -l lists the device number, but for the other I get an error message:
“Error: Error getting serial number string from device (pid=83, vid=1ffb).
I/O error.”
I noticed that on the one that doesn’t work correctly, the green LED blinks rapidly as soon as it is connected, and then starts to blink slowly, while on the other board it is solid the whole time. The User Guide says that:
"When you connect the jrk to USB, the green LED will start blinking slowly. The blinking continues until the jrk receives a particular message from the computer indicating that the jrk’s USB drivers are installed correctly"
Is there a way I can force this “message” from my computer, or some other solution and/or workaround?
The Windows utility doesn’t show any other errors from the usual “awaiting command” and "no power"
I’ve also successfully sent and received commands to the boards via the Pololu Serial Transmitter program in Windows, so it seems to be an issue with the host machine.
uname -a on Ubuntu 14.04 linux shows:
Linux Orion 3.13.0-24-generic #47-Ubuntu SMP Fri May 2 23:30:00 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
Any information on why one would work but not the other would be appreciated. Let me know if I can provide any more information that would help.
