We will be running motor at 50-60rpm, 90% of the time.
Measured the RMS current as 212mA and voltage as 8.7V.
The above shows that the test condition is less than the rated, will the motor life increases? -
We are testing at 150rpm (5% of the time in our application) which is beyond the rated specification, the voltage -12.74V and current- 334mA. Will the motor and lifetime gets affected?
Our general recommendation for brushed DC motor operation is 25% or less of the stall current. For our 34:1 Metal Gearmotor 25Dx52L mm MP 12V, that means keeping current draw below 450mA, so your conditions seem appropriate for ensuring a good motor lifetime.
- Patrick
Hi Patrick,
Thanks…
What will be the lifetime of these motors?
Unfortunately, we do not have our motor or gearbox lifetimes well characterized, and the lifetime will generally depend a lot on the specifics of your application, so that is something you would probably have to test for yourself in your actual system (perhaps in some accelerated way).
- Patrick
