Hi there,
I wish to know if it is possible to let me know where I can get the list of serial commands in order for me to control Jrk 12v12 USB Motor Controller with LABVIEW via Virtual COM Port.
Many Thanks.
Walter.
Hi there,
Many Thanks.
Walter.
Hello, Walter.
I moved your thread to the âMotor controllers/drivers and motorsâ subforum, which seemed more appropriate.
You can find a list of serial commands available for the jrk controllers in the âUsing the Serial Interfaceâ section of its userâs guide. Please note that you will need to set the jrkâs serial mode to be either âUSB Dual Portâ or âUSB Chainedâ so that it can accept commands from the USB virtual COM port. For more details on the jrkâs serial modes, see the âSerial Modesâ section of the guide.
- Amanda
Noted. Thanks a lots Amanda
Walter Lee
Hello Amanda S,
I hope you can help me.
I managed to interface LABVIEW with Jrk 12v12 controller but once I issued this command to controller below
For example,
Pololu Protocol = 0xAA, device number, 0x61,magnitude
AA0B 617F
I noticed that the target control range for actuator limit to 2048 - 4080 (0 - 127 = magnitude). Hence If I would like to have more flexible control in wider range i.e. 0 - 4095 ( magnitude?), what should I need to do? Please advice
Many Thanks/
Walter.
You can use the Set Target High Resolution command, which lets you set a 12-bit target, instead of the Set Target Low Resolution commands. You can find more details on that command in the âMotor Control Commandsâ section of the jrk userâs guide.
- Amanda
Thanks alot Amanda.
Finally, working now.
At First attempt,
BUT, I have problem regarding the READ Serial,
I am trying to GET Error Flags Occurred below,
For example to acquired any ERROR message,
0xAA, device number, 0x35
Hence
AA0B 35
I donât see any output result.
I also try on Variable Reading Commands,
For example, to acquired Scaled Feedback using two bytes
0xAA, device number, read variable command byte with MSB clear
Hence
AA0B A7
Also, donât see any output result.
Then,
I sent this command below which combination of 1 and 2
0xAA, device number, 061, magnitude, GET Error Flags Occurred, variable Reading Commands
AA0B 617F A733
Hence
From above 1, 2 and 3 = No result.
So, Not sure am I done anything wrong? Please advice.
At Second attempt,
Put a timing on READ Serial and noticed some value shown below after acquisition,
AA0B 617F A7 or AA0B 607F A7
Hence ,
I am not sure,
Both values above are in HEX? and Scaled Feedback?
Furthermore those both values are not consistent;can be 4200 and 2B0F, 4300 and 2C0F & etc. This is consider correct behavior?
Please advice.
Many Thanks.
Walter.
Your variable reading command in point 2 (âAA0B A7â) is wrong. For the Pololu protocol version of the Variable Reading command, you need to clear the MSB of the read variable command byte as stated in its documentation, so the 0xA7 should instead be a 0x27. Your method of combining commands in point (3) is not correct, and furthermore it would be best to just focus on doing one command at a time until you can get the command to work. I suggest reading the âUsing the Serial Interfaceâ section of the userâs guide to better understand how to use the jrk serial commands.
Anyway, your Get Error Flags Occurred command looks correct, so it seems like the main issue is that you are unable to receive data from the jrk through your program. Can you try sending the Get Error Flags Occurred command to the jrk using the Pololu Serial Transmitter Utility and seeing if the jrk responds? Please make sure that the configuration utility for the jrk is closed, since having the software open will cause the command to give unreliable responses. This is noted in the commandâs description under the âError Reporting Commandsâ section of the userâs guide.
- Amanda
Amanda,
Using Pololu Serial Transmitter v1.3
Get Error Flags Occurred,
Sent = 0xAA 0x0B 0x35
received: 00 â 00 â -> I guess it is correct
Sent = 0xAA 0x0B 0x27
received: 2F â/â 0F ââ -> Not sure it is correct?
Where,
According to âUsing the Serial Interfaceâ section of the userâs guide, I assume
0xA7 = 0x27
0xA5 = 0x25
0xA3 = 0x23
0xA1 = 0x21
Correct me if I am wrong , please
For the combination commands, would you mind to give me a few examples?
For example
Moving forward,
0xAA 0x0B 0x61 0x7F 0x35 0x27
I sent as above command; I can see the actuator is moving forward but I donât see any received data?
Many Thanks.
Walter
It sounds like you are not sure how to interpret the two bytes you are receiving back from the variable reading command. You can find a description of the two-byte response in the variable reading commands section of the userâs guide, which states:
In your returned response, 0x2F is the least-significant byte and 0x0F the most-significant, so if you reorder those bytes, you get [0x0F 0x2F], which converts to 3,887 in decimal. (If you want details on how to do the conversion, you can do an Internet search for âconverting HEX to decimalâ.)
As for your third point, the first part of your example sequence, [0xAA 0x0B 0x61 0x7F], is a valid serial command, so the jrk is able to process it, which explains why you see your actuator moving. The next two bytes (0x35 and 0x27) in that sequence are seen as data bytes, since their most-significant bits (MSbs) are not set to indicate to the jrk that they are a separate and new command, and are not recognized as part of the first (or Set Target Low Resolution Forward) command. The âCommand Protocolsâ section of the jrk userâs guide explains all of this. Each command in your byte string must follow the format of whichever protocol you are using so that it is recognized as a valid command. A proper command string for your example is [0xAA 0x0B 0x61 0x7F 0xAA 0x0B 0x35 0xAA 0x0B 0x27] (notice how each command is in the Pololu Protocol format).
Alternatively, if you are only sending these serial commands to one jrk, you can use the compact protocol for all your commands. So the three commands in your example could be sent like this: [0xE1 0x7F 0xB5 0xA7].
- Amanda
Yes Amanda. You are correct that I am not sure how to interpret the two bytes
Anyway, I am able to receive correct response in decimal correctly as well controlling using both protocols.
BTW, Do you want me to share the LABVIEW code in the forum? If yes please do let me know.
Many Thanks.
Walter.
Awesome! Iâm glad the problem is resolved; thanks for letting us know. Also, yes, please share your code. Iâm sure others on the forum would be interested in seeing it.
- Amanda
Not a problem, Amanda. Thanks a lot for your help
Kindly refer to the attachment.
Many ThanksâŚ
Walter.
POLOLU_CONTROL.vi (29.0 KB)
