I’m upgrading my project from a 10k regular pot to a Hall effect sensor.
The feedback input works just fine with the old pot but with the hall sensor the value won’t change.
I connected the Hall effect sensor to a joystick card (Leo bodnard) and works just fine.
Anything else I need to do?
This is the hall sensor
Thank you.
Ok finally figured it out. Moving the aux cable to 5v instead worked. All great now.
I am glad to hear you were able to get it working by switching to the 5V pin.
To clarify, the AUX pin on the Jrk is driven low periodically as part of the “Detect disconnect” feature. This feature is intended for use with potentiometers, and will generally only work correctly with resistive devices.
