I am trying to read the error messages form the Jrk G2 18V19 and it works via the Configuration Utility. However I also want to read the error messages with python.
For testing it I have not applied any power to the controller other than USB. In the Configuration Utility I see the message: “VIN is disconnected” also I see the “No Power” error count up as expected.
In my python code I do not always see the “No Power” bit.
In the output below I print out: “Errors currently stopping the motor” and “Error” both received form sending “-s” via the python command provided in the example.
After printing it out 10 times the result is that it only shows the “No Power” bit twice.
Also if i have power applied to the system I still get bit 2: " Motor driver error" also seen in the output below. The second bit is never shown in the Configuration Utility. I have also applied the pies of code that reads the data from the Jrk G2 module. Please help by explainig why i dont always see the “No Power” bit but do always see the " Motor driver error" bit (but not in utility)
Also by manualy using the jrk2cmd -s command in cmd i get the same results.
Best regards,
Marcel
PYTHON CODE OUTPUT
[‘Awaiting command’, ‘No power’]
error: 4, 0b100
error: 4, 0b100
error: 3, 0b11
No Power!
error: 4, 0b100
error: 3, 0b11
No Power!
error: 4, 0b100
error: 4, 0b100
error: 4, 0b100
error: 4, 0b100
error: 4, 0b100
def error_status(self):
self.jrk2cmd('--clear-errors')
status = yaml.safe_load(self.jrk2cmd('-s'))
#print(status['Overall status'])
print(status['Errors currently stopping the motor'])
error = status['Error']
print(f'error: {error}, {bin(error)}')
if 1 == (error >> 1 & 1):
print("No Power!")
print('\n')
def jrk2cmd(self, *args):
return subprocess.check_output(['jrk2cmd'] + list(args))
