These forums as well as some emails have helped me greatly in getting my Jrk G2 24v13 working well on my test bench.
I created a situation by accident that I can not seem to solve browsing the forums.
On my test rig, I have an encoder wheel linked to a motor using a small belt - this is just to test/program the Jrk. Everything works really well - exceeding my expectations however, the motor sheave (pulley) slipped off the motor causing the frequency feedback to drop to 0.
This caused the motor to rapidly spin up to max duty cycle. I found this to be an interesting situation - what if my encoder somehow lost physical contact with my project? I tried to address the potential failure.
I tried to use the Feedback Disconnect error to stop the motor by changing the minimum feedback error value above 0. This did not seem to have any effect - when I remove the belt duing the test, the motor would spin up to max duty cycle.
Is this scenario possible? That is, can I create an error to stop the motor if the physical link from the motor/gearbox is removed and the feedback drops to 0? The encoder is still physically attached to the Jrk so “Detect disconnect with power pin (AUX)” would not help in this situation.
Thanks again for a great little motor controller.
