Dear Pololu Forum,
I can’t run my motor(s), error 0x001 occurs.
I am currently working on my final year project using two JRK 12v12 controllers.
Everything is set up now, and I’ve connected all the pins as well as the bridge accordingly.
For testing purposes I wanted to run the motors without feedback (I know that they work, because I’ve connected them directly to the powersupply beforehand).
I set up the JRK to Feedbackmode “None”, set the Target to “2048” and Input to “serial” and applied the settings.
I get the error 0x001 (awaiting command) however, and nothing is moving, when i select “RUN”.
I’ve actually resoldered the contact pads already to be 100% certain that they are connected, the yellow LED is flashing, but nothing is happening.
Hopefully you can help me out
EDIT:
The problem just solved itself
Stupid me, I’ve actually not considered, that if I use the Inputmethod “Serial” there needs to be an input on the COM - Port. When I selected “Analog” it magically worked.
Thx either way.
Best Regards
Johannes
