Hi, if anyone can help me with this. Is there anyway that the motor microcontroller 12v12 jrk can use C coding in Linux to run the microcontroller??
We do not have any examples specifically for the jrk using C under Linux, but you should be able to get some tips by searching Google for “linux serial port example” or something similar.
You can also take a look at this example for the Maestro from another customer.
-Paul
hi paul again, how about thru USB??
I forgot to also link you to this example, which uses serial commands to talk to a Maestro instead of the native USB interface. You should probably try to modify this one to use the jrk’s commands instead of going with the one I posted earlier.
Both of these examples connect via USB.
-Paul
