Hello
I want to use a G2_18v25 controller to drive a 12V motor with either RC or I2C. The starting current of the motor is 60A and the continuous current is 10A.
Can I integrate the controller as a slave in an existing BUS system consisting of several sensors from Ncd.io?
https://store.ncd.io/product/i2c-shield-for-raspberry-pi-3-pi2-with-outward-facing-i2c-port-terminates-over-hdmi-port/
5V are present at the output of all sensor. Where do I connect the 5V from the sensor to the controller? I assume the 5V are necessary as supply voltage for the G2_18v25.
I will connect the remote control as described on Pololu - 4.5. Connecting an RC receiver.
Greetings Falk
The Simple Motor Controllers will automatically regulate their logic power from VIN or use USB power. The 5V pin is an output and you should not connect a separate supply to it.
- Patrick
Hi Patrick,
Thank you
