I urgently need help with my setup please!
I have a linear actuator with built in potentiometer feedback. I have connected this to a 2V supply and the wiper to pin EN1.
I want to control the length of the actuator using the PID controller on my RoboClaw 30A using the USB interface.
Here is my approach in software:
Start-up and connect over USB
Set encoder mode to 0x81
Set Velocity PID parameters (even though i am not controlling the velocity, but position - do i need this?!)
Set Position PID parameters
Reset encoders
Set the target position
After setting position sit in while loop and read feedback.
#include "roboclaw_driver/RoboClaw.h"
#include "roboclaw_driver/motor_state.h"
#include "roboclaw_driver/claw_state.h"
#include <ros/ros.h>
#include <ros/console.h>
#include "std_msgs/String.h"
#define ADDRESS 0x80
using namespace std;
class Driver {
private:
ros::NodeHandle nh_;
ros::Publisher pub_;
string port;
USBSerial serial;
RoboClaw claw_;
struct claw_properties_t {
string version;
int year;
} claw_properties;
int address_;
int serial_errs_;
public:
explicit Driver(const ros::NodeHandle &node)
pub_ = nh_.advertise<roboclaw_driver::claw_state>("claw_state", 5);
bool valid;
~Driver() {
void getState(void)
roboclaw_driver::claw_state state_;
uint8_t status;
bool valid;
int16_t m1_current, m2_current;
uint8_t mode1=5, mode2=5;
valid = claw_.ReadEncMode(ADDRESS, mode1, mode2);
state_.m1_enc = claw_.ReadEncM1(ADDRESS, &status,&valid);
state_.m2_enc = claw_.ReadEncM2(ADDRESS, &status,&valid);
state_.v = claw_.ReadSpeedM1(ADDRESS, &status, &valid);
state_.w = state_.m1_enc;
uint32_t p,i,d,qpps;
claw_.ReadPIDM1(ADDRESS, p, i, d, qpps );
state_.left_pid_pe = p;
state_.left_pid_ie = i;
state_.left_pid_de = d;
state_.left_qpps = qpps;
claw_.ReadPIDM2(ADDRESS, p, i, d, qpps );
state_.right_pid_pe = p;
state_.right_pid_ie = i;
state_.right_pid_de = d;
state_.right_qpps = qpps;
state_.main_voltage = claw_.ReadMainBatteryVoltage(ADDRESS,&valid);
state_.logic_voltage = claw_.ReadLogicBattVoltage(ADDRESS,&valid);
claw_.ReadCurrents(ADDRESS, m1_current, m2_current);
state_.m1_current = m1_current;
state_.m2_current = m2_current;
pub_.publish(state_);
void basic() {
ros::NodeHandle nh;
uint8_t status;
bool valid;
port = "/dev/roboclaw";//TODO: Don't hardcode port
serial.Open(port.c_str());
claw_ = RoboClaw(&serial);
//Use Absolute Encoder and Enable encoders in RC mode
claw_.SetM1EncoderMode(ADDRESS,3);
claw_.SetM2EncoderMode(ADDRESS,3);
//Set PID Coefficients
claw_.SetM1Constants(ADDRESS,0X00004000,0x00010000 ,0x00008000,3600);
claw_.SetM2Constants(ADDRESS,0X00004000,0x00010000 ,0x00008000,3600);
claw_.SetM1PstnConsts(ADDRESS,20000,2000,4,10000,10,0,21000);//D P I IMAX DEAD MIN MAX
claw_.SetM2PstnConsts(ADDRESS,20000,2000,4,10000,10,0,21000);//D P I IMAX DEAD MIN MAX
//Save settings in Roboclaw eeprom. Uncomment to save settings.
//roboclaw.WriteNVM(address);
claw_.ResetEncoders(ADDRESS);
uint32_t accel = 0, decel = accel, vel=1200, pstn=1300;
claw_.SpeedAccelDeccelPositionM1(ADDRESS,accel,vel,decel,pstn,1);
claw_.SpeedAccelDeccelPositionM2(ADDRESS,accel,vel,decel,pstn,1);
claw_.SpeedAccelDistanceM1(ADDRESS, 0, 3600, 100, 1);
claw_.SpeedAccelDistanceM2(ADDRESS, 0, 3600, 100, 1);
while (ros::ok()) {
ros::Duration(0.5).sleep();
getState();
ros::spinOnce();
};//End class
int main(int argc, char **argv) {
ros::init(argc, argv, "enc_demo");
ros::NodeHandle n;
Driver driver(n);
driver.basic();
