I’ve got a Jrk G2 18V19 Motor Controller and a Glideforce Linear Actuator (LACT12-500APL) which I’m using to open and close a door. This door weight and the mechanical advantage are well within the load limits of the actuator.
Circuit Wiring:
What I’m finding is that when the door reaches the fully closed or open position (software limits, not physical limits), it creates a huge voltage spike over 22V. This is causing our power supply with over-voltage protection to trigger and cut-out. If I stop the door during the stoke, it doesn’t impact it at all, it only seems to be at the programmed limits of the stoke.
Voltage Spike on Protected 12V PSU with Cut-Out (Opening Door)
Voltage Spike on Un-protected 12V PSU (Opening & Closing Door)
I’ve tried adding a rudimentary choke coil and capacitors (550uF) to the input but it didn’t make any difference.
Has anyone seen anything like this or can you help provide some suggestions to try? Happy to provide more information if required.
