Hi, I have an actuator with potmeter feedback (2321) driven by Jrk G2 21V3 motor controller (3142) is it possible to drive the actuator between two points with a switch?
If you want your actuator to move between two points based on the input from a switch, you can configure your Jrk for analog input mode and connect a switch to the SDA/AN pin such that you can alternate it between 5V and ground. Then, you can use the Jrk G2 Configuration Utility to adjust the maximum and minimum target positions that your input signal will map to. There is more information about the analog control interface in the “Setting up analog control” section of the Jrk G2 user’s guide.
- Patrick
Thank you very much for the help, it works now ![]()
-Rolf
