I wanted to know how to connect the 'DRV8825 Stepper Motor ’ to a Maestro controller. If that is een possible? I see the stepper driver pins for STEP and DIR but how does that map to teh Servo pins on the maestro.
It should be possible to control our DRV8825 stepper motor driver carrier with a Maestro by using the signal pins of two channels as digital outputs. However, if you are planning to control only stepper motors with the Maestro, I recommend using a microcontroller instead.
