I’m trying to make the common “wiper motor servo” (That involves using the internal RC servo circuit board and existing potentiometer and mating it to a windshield wiper using some kind of h-bridge amplifier). I have two basic questions:
Is it possible to use a single, off-the-shelf board that does the same exact thing as the board in the RC servo does, but outputs 12v, at around 5 amps instead of the typical 5v-6v 2amps? (so I can drive the wiper motor instead of the RC servo’s stock original motor)
If option one doesn’t already exist as an all-in-one package, how would you wire up one of pololu’s existing products so that I can simply amplify the already correct output coming out of a RC servo’s internal board up to 12v ~5 amps?
