Just wanted to confirm that this driver can also work with even more powerful NEMA motors. I would like to use the following motor: McMaster-Carr
I will limit the current to 4A.
Do you foresee any problems?
I generally expect the High-Power Stepper Motor Driver 36v4 to work fine with that stepper motor, although please note that since you will be limiting the current to a value lower than the motor’s rated current per phase, you will be limiting the potential torque and speed output from the motor. As long as that is not a problem for your particular application, then it should be okay.
