I have purchased the High Power 18v15 motor contorller from your site (Item 755).
I am currently having an issue with the speed control.
I have the ground and (V+) power coming from the controller (Through a 5V Regulator) to an arduino Uno R3.
I have PWM at Pin A0 and Direction as Pin 4.
My issue is with the speed control.
Currently the motor will only turn if the cycle is between 150 and 255.
However, the speed does not change in between these values.
Any assistance would be greatly appreciated.
Motor Testing With Pololu High Power Motor Driver 18v15
//DC Motor
const int Direction = 4; //Sets Motor Direction Pin to 4
const int Control = A0; //Sets Motor Control Pin to A0
char user_input; //Stores the Input of the User into the Serial Monitor
int x; //Upward Movment Step Variable
int y; //Downward Movement Setp Variable
//############################ SETUP ############################
void setup(){ //Setup Function
Serial.begin(115200); //Open Serial connection for debugging
pinMode(Direction, OUTPUT); //Initializes Direction Pin to Output
//Print function list
Serial.println("1. Up"); //Prints User Selection 1 as Up in Serial Monitor
Serial.println("2. Down"); //Prints User Selection 2 as Down in Serial Monitor
Serial.println(); //Prints Blank Line
//############################ LOOP #############################
void loop(){ //Main Loop Function
user_input = Serial.read(); //Read User Input and Enter Selected Mode
if (user_input =='1'){ //Run Move Up Cycle
MoveUp();} //Goto Move Up Function
else if(user_input =='2'){ //Run Move Dowm Cycling
MoveDown();} //Goto Move Down Function
//########################## Upward #############################
void MoveUp(){ //Upward Mode Function
Serial.println("Moving Upward"); //Print Moving Upward in Serial Monitor
for(x= 1; x<100000; x++){ //Loop the Upward Motion
digitalWrite(Direction,LOW); //Sets Direction to Up
analogWrite(Control, 255);} //Motor Movement at PWM Duty Cycle
Serial.println("Finished"); //Print Finished in Serial Monitor
analogWrite(Control, 10); //Stops Movement
Serial.println("Enter New Option"); //Print Enter New Option in Serial Monitor
Serial.println(); //Print Blank Line in Serial Monitor
//########################## Downward ###########################
void MoveDown(){ //Downward Mode Function
Serial.println("Moving Downward"); //Print Moving Upward in Serial Monitor
for(y= 1; y<100000; y++){ //Loop the Upward Motion
digitalWrite(Direction,HIGH); //Sets Direction to Down
Serial.println("Finished"); //Ptint Finished in Serial Monitor
Regards,
Ditch
