I need help regarding plot for the count of rotary encoder given in Pololu Motor 34:1 gear ratio.
I split your post off from where you originally posted, since this looks like a separate issue. What is the full product name or Pololu item # of the motor you are using? It is not entirely clear to me what you mean when you say “I need help regarding plot for the count”. Can you elaborate on your issue? For example, are you having trouble performing a calculation, can you not read the outputs from your encoder, etc.
-Jon
