Hi All, I recently bought the Zumo 32U4 to implement a student project that involves moving and traversing a particular path. This path is a particular black line on a white background .
The way I programmed it is to use the encoder to deduce distance covered and then use the qtr sensor to follow the black line. I then developed cases representing decisions it should make at different points/junctions. Here is the map we are asked to follow, and also, here is my code.
The question is, what is the best way to achieve this robot behavior and have it follow a predefined path with precision and accuracy?
#include <Wire.h>
#include <Zumo32U4.h>
// Zumo components
Zumo32U4Buzzer buzzer;
Zumo32U4LineSensors lineSensors;
Zumo32U4Motors motors;
Zumo32U4ButtonA buttonA;
Zumo32U4Encoders encoders;
Zumo32U4OLED display;
// Constants
const uint16_t maxSpeed = 200;
const float wheelDiameterCM = 3.5;
const float wheelCircumferenceCM = PI * wheelDiameterCM;
const int encoderCPR = 12;
const int gearRatio = 75;
const int countsPerRev = encoderCPR * gearRatio;
const float distancePerCountCM = wheelCircumferenceCM / countsPerRev;
#define NUM_SENSORS 5
unsigned int lineSensorValues[NUM_SENSORS];
int16_t lastError = 0;
// Case 1 logic
const float expectedDistanceCM_case1 = 6.8;
const float tolerance = 0.20;
const float lowerBound_case1 = expectedDistanceCM_case1 * (1.0 - tolerance); // ~5.44
const float upperBound_case1 = expectedDistanceCM_case1 * (1.0 + tolerance); // ~8.16
// Case 2 logic
const float expectedDistanceCM_case2 = 43.2;
const float lowerBound_case2 = expectedDistanceCM_case2 * (1.0 - tolerance); // ~34.56
const float upperBound_case2 = expectedDistanceCM_case2 * (1.0 + tolerance); // ~51.84
// Case 3 logic
const float expectedDistanceCM_case3 = 80.0;
const float lowerBound_case3 = expectedDistanceCM_case3 * (1.0 - tolerance); // ~64.0
const float upperBound_case3 = expectedDistanceCM_case3 * (1.0 + tolerance); // ~96.0
bool case1Done = false;
bool case2Done = false;
bool case3Done = false;
int caseCounter = 0;
// Custom character loading (optional)
void loadCustomCharacters()
static const char levels[] PROGMEM = {
0, 0, 0, 0, 0, 0, 0, 63, 63, 63, 63, 63, 63, 63
display.loadCustomCharacter(levels + 0, 0);
display.loadCustomCharacter(levels + 1, 1);
display.loadCustomCharacter(levels + 2, 2);
display.loadCustomCharacter(levels + 3, 3);
display.loadCustomCharacter(levels + 4, 4);
display.loadCustomCharacter(levels + 5, 5);
display.loadCustomCharacter(levels + 6, 6);
void calibrateSensors()
delay(1000);
for (uint16_t i = 0; i < 120; i++)
if (i > 30 && i <= 90)
motors.setSpeeds(-200, 200);
else
motors.setSpeeds(200, -200);
lineSensors.calibrate();
motors.setSpeeds(0, 0);
void setup()
Serial.begin(9600);
lineSensors.initFiveSensors();
loadCustomCharacters();
display.clear();
display.print(F("Press A"));
display.gotoXY(0, 1);
display.print(F("to calib"));
buttonA.waitForButton();
calibrateSensors();
// Wait for start signal
display.clear();
display.print(F("Ready..."));
display.print(F("Press A to go"));
while (!buttonA.getSingleDebouncedPress());
display.clear();
display.print(F("Go!"));
buzzer.play("L16 cdegreg4");
while (buzzer.isPlaying());
encoders.getCountsAndResetLeft();
encoders.getCountsAndResetRight();
void loop()
// PID Line Following
int16_t position = lineSensors.readLine(lineSensorValues);
int16_t error = position - 2000;
int16_t speedDiff = error / 4 + 6 * (error - lastError);
lastError = error;
int16_t leftSpeed = maxSpeed + speedDiff;
int16_t rightSpeed = maxSpeed - speedDiff;
leftSpeed = constrain(leftSpeed, 0, (int16_t)maxSpeed);
rightSpeed = constrain(rightSpeed, 0, (int16_t)maxSpeed);
motors.setSpeeds(leftSpeed, rightSpeed);
// Distance Tracking
static uint16_t lastDisplayTime = 0;
if ((uint16_t)(millis() - lastDisplayTime) >= 100)
lastDisplayTime = millis();
int16_t countsLeft = encoders.getCountsLeft();
int16_t countsRight = encoders.getCountsRight();
float distLeft = countsLeft * distancePerCountCM;
float distRight = countsRight * distancePerCountCM;
float avgDistance = (distLeft + distRight) / 2.0;
// Display distance
display.clear();
display.print(F("Dist:"));
display.print(avgDistance, 1);
display.print(F(" cm"));
// Serial debug
Serial.print("L: ");
Serial.print(distLeft, 2);
Serial.print(" cm, R: ");
Serial.print(distRight, 2);
Serial.print(" cm, Avg: ");
Serial.print(avgDistance, 2);
Serial.println(" cm");
// === CASE 1 Detection ===
if (!case1Done)
bool allSensorsBlack = true;
for (int i = 0; i < NUM_SENSORS; i++) {
if (lineSensorValues[i] < 900) {
allSensorsBlack = false;
break;
if (allSensorsBlack && avgDistance >= lowerBound_case1 && avgDistance <= upperBound_case1)
// CASE 1 Triggered: Turn right
motors.setSpeeds(100, -100);
delay(400);
caseCounter++;
case1Done = true;
display.clear();
display.print(F("Case 1: OK"));
display.print(F("Turn Right"));
Serial.println("Case 1: True. Turned Right.");
// === CASE 2 Detection ===
else if (!case2Done)
bool rightHeavy = lineSensorValues[3] > 900 && lineSensorValues[4] > 900 &&
lineSensorValues[0] < 500 && lineSensorValues[1] < 500;
if (rightHeavy && avgDistance >= lowerBound_case2 && avgDistance <= upperBound_case2)
// CASE 2 Triggered: Turn right
delay(400);
caseCounter++;
case2Done = true;
display.clear();
display.print(F("Case 2: OK"));
Serial.println("Case 2: True. Turned Right.");
// Removed while(1); so Case 3 can be reached
// === CASE 3 Detection ===
else if (!case3Done && case1Done && case2Done)
if (rightHeavy && avgDistance >= lowerBound_case3 && avgDistance <= upperBound_case3)
// CASE 3 Triggered: Turn right
delay(400);
caseCounter++;
case3Done = true;
display.clear();
display.print(F("Case 3: OK"));
Serial.println("Case 3: True. Turned Right.");
// You can add more actions here if needed
