Hello everyone!
I have just recently started my first serious electronics project, but i’m having some trouble with getting the parts to communicate with each other.
What I want to do is use a Mini Maestro 12-Channel USB Servo Controller to control two brushed DC motors via one Pololu Qik 2s9v1 Dual Serial Motor Controller, depending on inputs from various sensors also plugged into Maestro. I have already successfully connected the sensors to maestro and made a simple infinite loop script outputting a signal on one of the free channels.
The problem is I cannot figure out how to connect the Maestro to the motor controller and convince it to start spinning my motors, despite having read the user’s manual and the .c serial example codes.
I figured I have to connect the motor control’s TX to Maestro’s RX and somehow initiate the whole thing through Maestro control center (running W7 btw), but i’m terribly stuck here.
Any help would be greatly appreciated. As well as any additional resources on serial interface for total beginners and what is qik.
