I am writing code in C++. TIC 834 version 1.8.2.
I have used Serial control with an on/off type joystick and processor and the haltAndHold command works fine.
Now I am asked to implement an analog (potentiometer) type joystick. I have connected this to the TIC analog pins (as opposed to accomplishing this to the processor). This works nicely for controlling speeds as expected. I am continuing to use the processor for setup ,to set the stepsize(mode) and to halt/deenergize as needed.
However I am having trouble halting the motor quickly when the stick is centered. The motor ignores this and simply de-accelerates at the set rate. As a workaround I have set the deacceleration value very high (500E6) but I would prefer the Halt. Looking at the manual:
" If the control mode is something other than Serial / I²C / USB, this command will be silently ignored."
So I am guessing the Halt command no longer works in Serial mode?
What is the suggested work-around?
Thanks
Fritz
# Pololu Tic USB Stepper Controller settings file.
# https://www.pololu.com/docs/0J71
product: T834
control_mode: analog_speed
never_sleep: false
disable_safe_start: false
ignore_err_line_high: false
auto_clear_driver_error: true
soft_error_response: deenergize
soft_error_position: 0
serial_baud_rate: 9600
serial_device_number: 14
serial_alt_device_number: 0
serial_enable_alt_device_number: false
serial_14bit_device_number: false
command_timeout: 0
serial_crc_for_commands: false
serial_crc_for_responses: false
serial_7bit_responses: false
serial_response_delay: 0
vin_calibration: 0
input_averaging_enabled: true
input_hysteresis: 0
input_scaling_degree: cubic
input_invert: false
input_min: 45
input_neutral_min: 1887
input_neutral_max: 2092
input_max: 3935
output_min: -400000000
output_max: 400000000
encoder_prescaler: 1
encoder_postscaler: 1
encoder_unlimited: false
scl_config: default
sda_config: default
tx_config: default
rx_config: default
rc_config: limit_switch_forward active_high
invert_motor_direction: false
max_speed: 10000000
starting_speed: 0
max_accel: 40000
max_decel: 500000000
step_mode: 1
current_limit: 192
current_limit_during_error: -1
decay_mode: mixed50
auto_homing: false
auto_homing_forward: false
homing_speed_towards: 1000000
homing_speed_away: 500000
