Been using the Tic 36v4 in an application, so far only designing with your GUI. Now, moving on to create some shell scripts, I can’t seem to control the motors, or engage them using the CLI. The command in terminal will return a status okay. So it’s connected, but can’t engage or control the motors. When I switch back to gui, all is fine.
For what it’s worth, I don’t see a cu.usbmodemfa121 file in dev. If the program defaults to that virtual usb, but then why would the GUI work?
Your help, Brandon or anyone is much appreciated.
j.
