Newb here, both to Pololu and programming.
I’ve been trying to access position data on a Maestro 24 via device.getVariables(ByRef Stack() as Short) in Visual Basic 2010 and have run into problems with getting any data returned.
I’m wondering if the issues are with VB 2010 vs VB 2008 (used for the SDK), old/new versions of the SDK, or just plain ol’ ignorance on my part.
First off, the Maestro with one servo on channel 0 works just fine, both with the control center and the VB easyexample. The example code converted to VB 2010 without any issues, both in XP and Vista (different machines).
Using the SDK to get other information (device.stacksize, etc) works fine.
So I started following along same path as Marius. He (with David’s guidance) basically used the easyexample script but replaced device.settarget with device.getVariables(st), then added textboxes to display three values from the stack.
That code won’t run for me: I received “NullReference exception unhandled” errors for the dynamic array st() as soon as any line of code tried to use the array. Once that was fixed ( grain of salt there) I received " IndexOutOfRangeException" errors if I attempted to read any values for st() if I had already called getVariables(st). st.GetUpperBound would return a value of negative 1 (i.e., null) for st after calling getVariables(st). Before calling getVariables(st) st.GetUpperBound would return whatever value I initialized st() to.
VB2010 changed the way dynamic arrays are initialized; at least I think that might be at the root of the first problem. So I added to Marius’s code:
ReDim st(126)
Which got it running - until I tried to read the data.
Imports Pololu.UsbWrapper
Imports Pololu.Usc
Imports System
Imports System.Text
Imports System.ComponentModel
Public Class MainWindow
Public Property Stack As Object
Dim st As Short()
Dim ss As Int32
Dim cs As Int32
''' <summary>
''' Attepts to get variables from the stack
''' </summary>
Public Sub TryGetVariables()
ReDim st(126)
st(0) = 0
TextBox1.Text = st.GetLowerBound(0)
TextBox2.Text = st.GetUpperBound(0)
Try
Using device As Usc = connectToDevice() ' Find a device and temporarily connect.
ss = device.stackSize
' device.Dispose() is called automatically when the "Using" block ends,
' allowing other functions and processes to use the device.
End Using
Catch exception As Exception ' Handle exceptions by displaying them to the user.
displayException(exception)
End Try
TextBox3.Text = st.GetLowerBound(0)
TextBox4.Text = st.GetUpperBound(0)
' TextBox5.Text = st(0)
End Sub
''' <summary>
''' Connects to a Maestro using native USB and returns the Usc object
''' representing that connection. When you are done with the
''' connection, you should close it using the Dispose() method so that
''' other processes or functions can connect to the device later. The
''' "Using" statement can do this automatically for you.
''' </summary>
Function connectToDevice() As Usc
' Get a list of all connected devices of this type.
Dim connectedDevices As List(Of DeviceListItem) = Usc.getConnectedDevices()
For Each dli As DeviceListItem In connectedDevices
' If you have multiple devices connected and want to select a particular
' device by serial number, you could simply add some code like this:
' If dli.serialNumber <> "00012345" Then
' Continue For
' End If
Dim device As Usc = New Usc(dli) ' Connect to the device.
Return device ' Return the device.
Next
Throw New Exception("Could not find device. Make sure it is plugged in to " & _
"USB and check your Device Manager.")
End Function
''' <summary>
''' Displays an exception (error) to the user by popping up a message box.
''' </summary>
Sub displayException(ByVal exception As Exception)
Dim stringBuilder As StringBuilder = New StringBuilder()
Do
stringBuilder.Append(exception.Message & " ")
If TypeOf exception Is Win32Exception Then
Dim win32Exception As Win32Exception = DirectCast(exception, Win32Exception)
stringBuilder.Append("Error code 0x" + win32Exception.NativeErrorCode.ToString("x") + ". ")
End If
exception = exception.InnerException
Loop Until (exception Is Nothing)
MessageBox.Show(stringBuilder.ToString(), Text, MessageBoxButtons.OK, MessageBoxIcon.Error)
End Sub
Public Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
TryGetVariables()
End Sub
Private Sub MainWindow_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
End Sub
End Class
note- TextBox5.Text = st(0), which in the best of all possible worlds would display the data I want, is commented out to allow the program to run.
I guess I have several questions.
- If someone could explain or point me towards an answer, I’d be most grateful.
- Is using VB 2008 (vs 2010) likely to be a path of less resistance for using Pololu and perhaps other controllers?
- My previous programming experience is old and atrophied, so I’m really just getting started -both with learning an OOP language and learning about machine interfaces in general. Would switching to C# instead of VB be likely to increase or decrease the slope of the learning curve? Down here at the bottom of the hill, that is.
Thank you!
hardware: maestro-24, RC servo on channel 0, Core2Duo PC
software: latest version of USB SDK(2010-11-19), Visual Basic 2010 Express, XP SP3 32-bit
