The RPM shown on our website is the maximum speed (under no load) at a specific voltage. Greater speeds can be achieved by increasing the voltage supplied to the motor, but this will decrease the life of the motor. The speed is generally controlled by changing the supplied voltage or by pulse width modulating the voltage using a motor driver or motor controller.
To drive the motors, you will probably need a motor driver or motor controller. Our “Motion Control Modules” explains the difference between a motor driver and motor controller and links to categories for each.
