My first post .
I have recently bought several G2 high power motor drivers. At first everything worked fine, but then after a day motor driver started overheating(I did not change the setup) and this was happening while the motor was turned of. The battery voltage was 12.1V but the Vm pin was only at 11.5V.
How can I fix that?
Can you post pictures that show the motor driver and all of your connections including any soldered connections you made? Do you have a datasheet or any other specifications for your motor you can provide? Does the motor driver get hot if you disconnect everything but VIN and GND? How many of your motor drivers have this problem?
-Nathan
