Hi
I want to use remote receiver FLYSky, FS-GR3E to control/drive 2 motors. The motor is 12V/200W.
Is DMC01 suitable?
Thanks
Hong
Hi
Is DMC01 suitable?
Thanks
Hong
Hello, Hong.
The TReX Dual Motor Controller (DMC01) might be underpowered for that motor, but it is hard to say without knowing the motor’s stall current. You might also consider a pair of our Simple Motor Controllers. They each only control one motor, but two can be connected to do differential drive when using RC control, and there are higher power options available.
If you post more details for you motor like a datasheet, I might be able to offer more advise.
-Dan
Thanks Dan
I can limit current to 13A for the motor. it is not problem.
Is it ok using FS-GR3E to control MC01?
Thanks
Hong
Hello, Hong.
As long as your FS-GR3E system outputs standard RC hobby signals, it should be fine with the TReX.
-Dan
