Have an Arduino UNO and attempting to work with a VNH5019 motor driver carrier from Pololu.com. https://github.com/pololu/dual-vnh5019-motor-shield Loaded the zip file to folder, used Sketch – include in library – ZTried by adding zip. Library… used the zip file download and still get this error message;
Demo.ino:1:36: fatal error: DualVNH5019MotorShield.h: No such file or directory
Can see the file in Arduino files under sketch_DualVNH5019MotorShield.
Am I placing it in the wrong folder?
Thanks
sketch_DualVNH5019MotorShield.ino (1.64 KB)
Thank You not sure why it works this way and not as the instructions read.
Not sure if this should be a new topic? Got the VNH5019 wired to Arduino UNO as per instructions https://www.pololu.com/product/1451/pictures Compiled This sketch_DualVNH5019MotorShield.ino (1.64 KiB) Downloaded 1 time and uploaded it to UNO. There are no lights on the driver blinking or not blinking. What am I missing? Yes retried and rechecked all of this to the best of my ability.
I am sorry you are having problems using your VNH5019 carrier. It sounds like you initially did not have the libraries installed correctly but were able to fix it. Its unclear what is causing your current issue. Could you tell us more about your setup? What are you using for your power supply? What linear actuator are you driving? Could you post the program you have loaded onto your Arduino Uno using the [ code ] tags? Could you also post pictures of your setup?
- Jeremy
Thank You Jeremy, I found a less expensive and easier way to accomplish my goal. So I am going to give it away to someone who has more knowledge of these things.
RJ
Thanks for letting us know. Good luck on your project.
- Jeremy
