After reading over the info on the A4988 I have a question about the method of enabling half stepping. MS1 needs to be high. OK to just tap the 5V that feeds the driver power ( NOT motor power ) ? Or should MS1 get its high signal from a digital I/O on the Arduino?
[quote]MS1 needs to be high. OK to just tap the 5V that feeds the driver power ( NOT motor power ) ? Or should MS1 get its high signal from a digital I/O on the Arduino?[/quote]Either method works. With the second, you have program control.
OK… thanks for the reply. I’ll just hard wire it. There will be no need to change stepping rate once things are set up.
