Electrichal schematic/datasheet
Hello i am trying to integrate Motoron M2T550 Dual I²C Motor Controller in a PCB , where can i find the datasheet or a schematic to make a footprint ?
Thank you in advance
We do not publish the schematic for the Motorons, but you can find the Motoron user’s guide and a few other files that might be useful for making a footprint (like a 3D model and drill guide DXF) on the board’s product page under the “Resources” tab.
- Patrick
Thank you !
Found what i needed so far but i can’t find anywhere any info regarding the power consumption of the M2T550 , i am talking about the logic power consumption because it only woks if i power it from the Arduino 3.3V rail
I expect the current draw from the logic power supply to be less than 20 mA. Was there a different power supply you were hoping to use for your logic power source that was not working?
- Patrick
Thank you for the reply , I am trying to use it with arduino nano esp32 with 3.3V logic , but if i tried to power it from Lipo Rider Plus it won’t start , it only works if i power it from the 3.3 V rail of the Arduino Nano Esp32 , So now my question is if i can power 3x M2T550 and 3x ina219 from the Arduino 3.3 V Rail
I think either of those methods for powering your Motoron controllers should be okay. Can you post some pictures of the setup that was not working that show all of your connections? Can you try monitoring the Motoron’s VDD pin to see what is going on?
- Patrick
