Hello all, I’m trying to run a stepper with the DVR8825. Below is my environment…
Arduino Uno
DVR8825
Stepper Motor: Bipolar 200 st/rev, 2.8V, 1.7A/phase(Pololu item #2267)
I have followed the directions to set the current limit by setting the voltage to 850mv.
The motor runs really well with this code…
int dirPin = 8;
int stepperPin = 7;
void setup() {
TWBR = ((F_CPU /400000l) - 16) / 2; // Change the i2c clock to 400KHz
//AFMS.begin(1000); // OR with a different frequency, say 1KHz
pinMode(dirPin, OUTPUT);
pinMode(stepperPin, OUTPUT);
void step(boolean dir,int steps){
digitalWrite(dirPin,dir);
delay(50);
for(int i=0;i<steps;i++){
digitalWrite(stepperPin, HIGH);
delayMicroseconds(400);
digitalWrite(stepperPin, LOW);
void loop(){
step(true,2000);
delay(500);
step(false,2000);
delay(500);
But it’s too slow for my application. I’ve tried tweaking this code but with little success So I next decided to use AccelStepper. With this code(below) my motor is capable of moving sufficiently. But it stalls, whines, skips etc. I have tweaked this code to death trying to make it work. Afresh set of eyes to look this over is much appreciated…
[code]//This is an example of how you would control 1 stepper
#include <AccelStepper.h>
int motorSpeed = 9600; //maximum steps per second (about 3rps / at 16 microsteps)
int motorAccel = 80000; //steps/second/second to accelerate
int motorDirPin = 8; //digital pin 8
int motorStepPin = 7; //digital pin 7
//set up the accelStepper intance
//the “1” tells it we are using a driver
AccelStepper stepper(1, motorStepPin, motorDirPin);
void setup(){
stepper.setMaxSpeed(motorSpeed);
stepper.setSpeed(motorSpeed);
stepper.setAcceleration(motorAccel);
stepper.moveTo(4000); //move 32000 steps (should be 10 rev)
void loop(){
//if stepper is at desired location
if (stepper.distanceToGo() == 0){
//go the other way the same amount of steps
//so if current position is 400 steps out, go position -400
stepper.moveTo(-stepper.currentPosition());
delay(1500);
//these must be called as often as possible to ensure smooth operation
//any delay will cause jerky motion
stepper.run();
}[/code]
Thanks!
Paul
