Motor Controller: Low-Voltage Dual Serial Motor Controller
Micro Controller: Basic Stamp 2
Desired Operation: 2 motor mode, default motor numbers
Motors: Tamiya 70168
Power: Motor: Power 2 - 1.5v AA / Micro/Motor Controller – 5v regulated on Basic Stamp Homework Board
Wiring Deviations: 0.1uF capacitors aren’t installed
I am new to motor/microcontrollers and have been experiencing difficulty controlling two motors independently. The motors will only respond to the following commands.
If I use 1 as the motor number both motors turn in one direction.
SEROUT 0, 84, [$80, 0, 1, 127]
If I use 0 as the motor number both motors turn in the opposite direction.
SEROUT 0, 84, [$80, 0, 0, 127]
I tried using the default motor numbers and others (0-20) just for testing with no luck.
I am fairly sure I am the cause of the problem since I didn’t read the documentation all the way through. I started by issuing the configuration command at the start of my test program:
SEROUT 0, 84,[$80,2,2]
LOW 2 'reset motor controller
HIGH 2
PAUSE 100
I also had a return statement at the end of my test program which would cause the application to loop.
I figured it would be a good idea to start from scratch but I am having some trouble getting there. Does anyone have a BS2 script to erase the motor controller eeprom and reset the factory defaults?
Any other suggestions would be greatly appreciated!
Thanks,
Eric
Same behavior with the following script:
