I am trying to run the motor given on the link (https://www.pololu.com/catalog/product/2286) with Dual MC33926 but I’ve run into several problems. First let me explain my setup:
I am using Dual MC33926 driver with this pin configurations:
EN -------- Arduino Digital 7
M1IN1----- Arduino Digital 4
M1IN2----- Arduino Digital 5
M1D2 ----- Arduino Digital 10 (PWM)
M1D1 ----- Arduino GND 1
GND ------ Arduino GND 2
VDD ------- Arduino 5 V
VIN -------- Power Source (+) 7 V
GND ------- Power Source (-)
M1OUT1 and M1OUT2 to Motor
and I am using this code:
#define stby 7
#define motoryon1 4
#define motoryon2 5
#define motorhiz 10
int incoming=0;
int derece;
void setup(){
pinMode(stby,OUTPUT);
pinMode(motoryon1,OUTPUT);
pinMode(motoryon2,OUTPUT);
digitalWrite(stby,HIGH);
digitalWrite(motoryon1,HIGH);
digitalWrite(motoryon2,LOW);
Serial.begin(9600);
void loop(){
if(Serial.available()>0){
incoming=Serial.read()-'0';
derece=map(incoming,0,9,0,255);
analogWrite(motorhiz,derece);
Serial.println(derece);
delay(1000);
As you can see I am giving a number from Serial port and then mapping it to PWM values. Normally the motor is running but when I watched the signal with an oscilloscope I’ve seen some problems:
Firstly my motor is not running until the PWM rate is 120 (assuming full PWM is 255), so it starts to run with high velocity, but I need to start running on slower speeds. When I measure the voltage on lower PWM like 50 I see 0.3-0.5 V but it supposed to be higher when you calculate it with a linear relation (e.g. x/7v = 50/255). On the other hand when the motor is running I can decrease PWM rates to for example 50 and I see voltages like 1.2-1.5 V.
Second problem occured when I measured the output signal given from MOUT pins. Here it means the PWM outputs. When I doesnt give a PWM rate from Arduino the voltage output stays at zero as expected. However when I start to run the motor with 1/2 duty cycle. The signal I see has a square wave with its amplitude on 7 V and its base on 2 V which should be 0 V. Well this explains why I measure highter voltages than I expected on different PWM rates but I still doesnt understand why this problem happens. Additionally the wave I see on oscilloscope is not an exact square wave. The rising edge seems a bit leaned.
I will be glad if you can tell me how to fix this problems. Normally I am trying to do position control on my motor with a potantiometer. However It starts to run on high speeds so I get errors like 80-90 degrees, which makes it hard to control with PID or something like that. Thanks for the help already
