im using the DRV8835MotorShield library GitHub - pololu/drv8835-motor-shield: Arduino library for the Pololu DRV8835 Dual Motor Driver Shield for Arduino http://www.pololu.com/product/2511 with a DRV8835 in in/in mode on an Adafruit feather esp8266. I used my own pin mapping instead of the default pin maps.
The issue I am having is when setting positive speeds everything works fine. A speed of 0 stops the motor, a speed of 400 is full speed.
When I want to reverse the motor using negative speeds it seems that -1 is full speed and -400 is stopped. Why is it flipped like this and how can i correct this. I would expect -400 to be full speed in reverse.
