I understand i need to give voltage to the Motor Driver itself. Do i have to give it 3.7v since im running 3.7v motors? Or how much voltage do i actually give the motor driver if im controlling 2 motors that are rated at 3.7v?
I want to be able to use PWN to change the speed of the motor.
Bear in mind, if you can’t find a 3.7V power supply (That is a little uncommon, though sounds perfect for LiPo batteries), then you can do use a 5V supply and implement a PWM limit.
So max PWM * (3.7V) /(5V) = PWMlimit.
So if you’re using arduino it has a pwm from 0-255. So you don’t want to PWM more than 189, to simulate 3.7V from your 5V supply.
