Hello!
i use DRV8825 boards with MKS GEN 1.4 with a 24v supply voltage in 1/32 mode,
as my motors are NEMA 17 rated current 1.2 A,
i had set the Vref to 0,6 Volt,
but do you think i had to solder the pin 19 to the FAULT or to the pin M2?
as said here:
Hello Claire,
For the moment no, they seems to run well… but i haven’t tryied to print yet…(i’m waiting the Inductive sensor)
and they doesn’t seams to be quieter than my olders A4988!
what could change if i solder them for the fast mode?
thanks!
If you have not noticed any issues, I suggest trying the drivers without modification first. Slow decay generally gives a smoother torque output than fast decay, but fast decay is generally better for faster speeds. If you are interested in trying to see more about how your system will behave with different decay modes, this spreadsheet simulation tool might be useful.
We do not make any stepper motor driver carriers with Trinamic chips on them. You should contact the manufacturer of that driver to find out how they recommend setting its current limit.
