I am working on a project where I would like to drive two stepper motors simultaneously with an Arduino Uno. I have two of the A4988 Stepper Motor Drivers and two Stepper Motors (Stepper Motor: Bipolar, 200 Steps/Rev, 35×28mm, 10V, 0.5 A/Phase).
You would typically connect those A4988 driver carriers to your Arduino Uno the same way shown in the “Minimal wiring diagram for connecting a microcontroller to an A4988 stepper motor driver carrier (full-step mode)” on the A4988 product page.
If you want both stepper motors to step at the same time and always in the same direction as each other, you can connect the STEP pins and DIR pins from both carriers to the same pins on the Arduino.
I am good with that part so far. What it I want them to turn at different speeds at the same time? Is there a better way than driving the step outputs HIGH manually in a loop?
Also how long to the step outputs need to be high to register? Is 2 ms enough?
I do not have any specific examples I can direct you to for that particular application, but you should be able to do that using non-blocking code.
The minimum HIGH and LOW pulse width for the A4988 is 1μs, so 2ms should be fine. You can find those values in the “Allegro A4988 stepper motor driver datasheet” located under the “Resources” tab of the A4988 product page.
