Hey Everybody,
I recently purchased a bipolar stepper motor from Jameco ([https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&freeText=2158531&langId=-1&storeId=10001&productId=2158531&krypto=7QuTBIeAvehd%2BfNIxtC1o6GgeKn5dPXjF4JcB7nZJKGGDhdX42T%2FtuI%2BFD3noOZsU2BcjJYHWfJlE2ZT5bjsPOsbK9dCIYL5IoY6TG4MSAM%3D&ddkey=https%3AStoreCatalogDrillDownView](http://Jameco P/N 2158531)).
I also purchased the A4988 Stepper Motor Driver from Pololu.
I am trying to figure out how fast I can turn the motor output shaft in RPM’s. I am currently driving the motor in FULL steps.
Going strictly by the code, and the 750 microsecond time delay between trigger, delay, pull low, then delay for a total of 1500 microseconds per step, I calculate a shaft speed of 200RPM. When I manually timed this, I got about 160RPM(attributable to overhead in my code)…I should probably look at this in my oscilloscope for the actual RPM’s.
I see a few facts and figures I the A4988 data sheet like:
–5000 hour bearing life at 1000 full steps /sec
–max starting pulse rate of 1600 pps half step no load
With all of this being said, HOW fast should I really be able to drive this motor at no load?
In order to drive the device, I wrote some very basic code in C for an Arduino Uno:
#define STEP 2
#define DIR 3
#define MS1 4
#define MS2 5
#define MS3 6
#define EN 7
int t = 750;
void setup()
//set inputs/outputs
pinMode(STEP, OUTPUT);
pinMode(DIR, OUTPUT);
pinMode(MS1, OUTPUT);
pinMode(MS2, OUTPUT);
pinMode(MS3, OUTPUT);
pinMode(EN, OUTPUT);
//initialize stepper for full step and direction
digitalWrite(MS1, LOW);
digitalWrite(MS2, LOW);
digitalWrite(MS3, LOW);
digitalWrite(DIR, HIGH); //Pull direction pin low to move "forward"
digitalWrite(EN, LOW);
void loop()
while(1)
digitalWrite(STEP,HIGH); //Trigger one step forward
delayMicroseconds(t);
digitalWrite(STEP,LOW); //Pull step pin low so it can be triggered again
TIA,
–Neal
