I have an application that uses both servo and stepper motors in a robotic camera arm. The cameras have three small built-in small stepper motors. The arm has three servos for pan/tilt/roll. I was planning to use an Arduino as the motor controller, using its digital I/O lines to drive step/direction on three Pololu DSV 8834 stepper drivers and tx/rx to control a Maestro 6 for the servos.
As an alternative - Can I use the Maestro 12 to drive BOTH the servos and the DRV 8834s, eliminating the need for the Arduino? My thought is that Maestro positions 1/2/3 drive the servos, then 4/5 are step/direction for the first DRV 8834, 6/7 for the second and 9/10 for the 3rd, leaving 8 open for potential PWM use. The pins being used for step/direction would be set as Digital Outputs, but I am new at this and uncertain about the rate and accuracy with which they could be toggled.
In this application it is unlikely that more than two motors would be moving at any given point in time and speed is not critical, but holding torque on one of the servos is (20kg-cm). The Maestro would be controlled using TX/RX from my main processor instead of the Arduino.
