Disabled Commands for Analog Mode on TIC825
I note that the “Halt and Set Position” command in C++ does not seem to work in analog control. Viewing the doc it seems to only work for Serial… control.
I seem to be seeing some similar issues for other commands.
Is there a list of commands that do not work with analog control?
thanks-Fritz
Hello, Fritz.
We do not have a separate list of commands that require the control mode to be set to Serial/I2C/USB, but there is a note for each applicable command in the “Command Reference” section of the user’s guide. These commands include: Set target position, Set target velocity, Halt and set position, and Halt and hold.
Thanks Brandon. After some consideration I am letting the processor control the stick and just setting the Pololu to serial/I2C/USB. It works fine and give me the full control provided as seen in your TIC.h library.
Fritz
