DipTrace Wixel Model?
I’m planning to integrate a Wixel into a robotics project, and plan to create a PCB to house the Wixel, a 5V LDO regulator, and a 1NA169 high-side current sensor. My EDA software of choice is DipTrace, so I’d like to know if you have a DipTrace model for the Wixel part?
TIA,
Frank
Well, I did find ‘wixel.lbr’ in the ‘Resources’ section for the Wixel, but it doesn’t appear to be a valid XML file. Am I missing something?
TIA,
Frank
OK, so I found a post that suggested that older .lbr files were in binary format, which this certainly seems to be. Can anyone please load this into Eagle and re-save it as a XML file?
TIA,
Frank
Never mind. Found a post that suggested that the FreeWare version of Eagle could be used to convert a binary .lbr to an XML on, and this turned out to indeed be the case. The attached converted .lbr works fine in DipTrace
Wixel_XML.lbr (14.1 KB)
Unfortunately, we do not use DipTrace, so we do not have any resources specific to it, but I am glad you found a solution to your problem, and thank you for sharing it!
