Things have been going smoothly for the most part. My interface to powering the motors has been this function from the library (this is for the first motor)
I have gotten to a point in my poking around where I can no longer drive the motors, even if I provide power of 400.
I am wondering if I may have either done something to damage the shield or if simply my battery needs recharging. Using my multi-meter, I did a reading on the 7.2V battery, which read ~6.4/6.5V.
Can anyone confirm this means the battery requires recharging to adequately power the motors via the shield?
Yes, 6.4-6.5V is severely discharged for a 7.2V NiMH battery pack, so the first thing you should try doing is charging the batteries. When fully charged, each cell should be around 1.4V, so the fully-charged voltage of that battery pack should be closer to 8.4V at that point. It is generally a good idea to charge it when the voltage drops below 1.1V per cell (6.6V for that pack).
If that does not fix the problem, you can post pictures of your setup that show all of your connections, as well as the code you are currently using, and I would be happy to take a look.
The iMAX 6BAC V2 is a well made charger that works with various kinds (e.g. different battery chemistries, nominal voltages, etc.) of battery packs, including the 7.2V NiMH pack you are using.
However, please note that it is has a lot of more complex features and abilities that are not necessary if you are just planning on using it with NiMH batteries. So, if that is the case, you can probably find a simpler charger, although I do not have any specific suggestions for one.
