Hello, I need to make closed loop dc motor speed control with optical encoder.
Motor: Mabuchi 18 V with encoder
Operates on 18 VDC nominal
Recommended voltage range: 6 - 24 VDC
No load speed at 18 V: 3,400 RPM
No load current: 50 mA
Stall current: 3.2 A
Hello. Yes, the Jrk 21v3 will probably work for your application, though you have not said how many pulses per second you are expecting to get from the encoder during operation. If that is too high or too low, it would be a problem.
The encoder seems to have 50 lines so that means 5 pulses per revolution.
Motor is 3400 rev. max that is 3400 * 50 = 170 000 pulses per minute or 2833 per second.
Is that OK?
I would like to set the motor speed min/max etc. via USB (I see you can do it by ) or by using POT.
A pulse rate of 2833 pulses per second should be fine. There is a tradeoff between how much resolution the PID algorithm has to work with and how fast the PID algorithm can update. I would probably set the PID Period to something like 100ms, so that the number of pulses you get in a period varies between 0 and 283 and the speed will be updated 10 times per second.
