Hi all! I am trying to drive two engines with two Pololu SMC G2 controllers, what I have basically done is modify the example program in c # and then adapt it to the voice control program that I am building. The Example works fine, it does not give errors and it detects the two SMC G2 controllers, but when I use the buttons of the example program, I do not get a response, I pass the program here to see if someone can help me. Thanks
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Text;
using System.Windows.Forms;
using Pololu.SimpleMotorControllerG2;
using Pololu.UsbWrapper;
namespace Pololu.SimpleMotorControllerG2.SmcG2Example1
public partial class MainWindow : Form
public MainWindow()
InitializeComponent();
/// <summary>
/// This function runs when the user clicks the Forward button.
/// </summary>
void forwardButton_Click(object sender, EventArgs e)
try
using (Smc device = connectToDevice("52FF-6D06-8365-5650-1248-2467")) // Find a device and temporarily connect.
device.resume(); // Clear as many errors as possible.
device.setSpeed(3200); // Set the speed to full forward (+100%).
using (Smc device = connectToDevice("52FF-6E06-8365-5650-4655-2467")) // Find a device and temporarily connect.
catch (Exception exception) // Handle exceptions by displaying them to the user.
displayException(exception);
/// <summary>
/// This function runs when the user clicks the Reverse button.
/// </summary>
void reverseButton_Click(object sender, EventArgs e)
try
device.setSpeed(-3200); // Set the speed to full forward (+100%).
device.setSpeed(-3200); // Set the speed to full reverse (-100%).
/// <summary>
/// This function runs when the user clicks the Stop button.
/// </summary>
void stopButton_Click(object sender, EventArgs e)
try
device.stop(); // Activate the USB kill switch
/// <summary>
/// Connects to a Simple Motor Controller using native USB and returns the
/// Smc object representing that connection. When you are done with the
/// connection, you should close it using the Dispose() method so that other
/// processes or functions can connect to the device later. The "using"
/// statement can do this automatically for you.
/// </summary>
Smc connectToDevice(String serialNumber)
// Get a list of all connected devices of this type.
List<DeviceListItem> connectedDevices = Smc.getConnectedDevices();
foreach(DeviceListItem dli in connectedDevices)
// If you have multiple devices connected and want to select a particular
// device by serial number, you could simply add a line like this:
if (dli.serialNumber != "52FF-6E06-8365-5650-4655-2467")
continue;
else if (dli.serialNumber == "52FF-6D06-8365-5650-1248-2467")
continue;
Smc device = new Smc(dli); // Connect to the device.
return device; // Return the device.
throw new Exception("Could not find device. Make sure it is plugged in to USB " +
"and check your Device Manager (Windows) or run lsusb (Linux).");
/// <summary>
/// Displays an exception to the user by popping up a message box.
/// </summary>
public void displayException(Exception exception)
StringBuilder stringBuilder = new StringBuilder();
do
stringBuilder.Append(exception.Message + " ");
if (exception is Win32Exception)
stringBuilder.Append("Error code 0x" + ((Win32Exception)exception).NativeErrorCode.ToString("x") + ". ");
exception = exception.InnerException;
while (exception != null);
MessageBox.Show(stringBuilder.ToString(), this.Text, MessageBoxButtons.OK, MessageBoxIcon.Error);
private void MainWindow_Load(object sender, EventArgs e)
me. Thanks
